How to see current wireless tx power?
erhtun
Is there a ssh command to see current wireless tx power of RT-AX68U? In web interface, it doesn't show tx power in mW unit.
Yes, there are:
This is for 2.4GHz
wl -i $(nvram get wl0_ifname) txpwr_target_max
And this is for 5GHz
wl -i $(nvram get wl1_ifname) txpwr_target_max
You need to enter it in SSH, I assume you already know how to use SSH.
For other models, the commands are almost universal, but for the GT-AXE16000 there are some differences there (read more)
  • Like
Reactions: aru
Thank you for your reply.
I get theese results
Bash:
Maximum Tx Power Target (chanspec:0x1001):    13.50  13.50  13.50
Maximum Tx Power Target (chanspec:0xe32a):    16.25  16.25  16.25
Are theese result in mW unit?
current it is not max:
2.4
wl -i $(nvram get wl0_ifname) txpwr_adj_est
5
wl -i $(nvram get wl1_ifname) txpwr_adj_est
maximum:
Maximum Tx Power Target (chanspec:0x180b):      26.00  26.00  26.00  26.00
Maximum Tx Power Target (chanspec:0xeb32):      26.00  26.00  26.00  26.00
current:
Last adjusted est. power (chanspec:0x180b):     25.50  25.75  26.25  25.25
Last adjusted est. power (chanspec:0xeb32):     26.50  26.25  26.50  26.00
Bash:
My guess is they are in dBm - 13.5 dbm is 22 mW and 16.25 dbm is 42mW.
Do you have your GUI set to something less than the highest setting? Those seem a bit on the low side but if you've decreased the power then they make sense.
My AC68U reports 18.5 for 24. and 22 for 5
That's assuming the router is not incorporating the antenna gain into the dBm result it is reporting, I don't know if these routers do or not. If they do, then you'd need to deduct that from the result, then convert it to mW to get an accurate reading.
