How to set VLAN ID for internet connection on RT-BE92U
chrisisbd
I have a new (to me) RT-BE92U that I'm aiming to use with my new fibre broadband connection. The ONT box uses PPOE to connect and it requires a VLAN ID in addition to the user name and password.
Installing the Asuswrt-Merlin software (version 3006.102.53) means that the VLAN ID setting in the WAN settings has disappeared. So where do I set the VLAN ID now?
OK, thanks, what should the other parameter be set to? Leave it at 0?
I only changed it to manual setting, then added 911 in Internet VID (that's what my provider requires), I didn't touch any of the other parameters.
OK, thanks, that's brilliant. There's currently a problem with the connection so I can't try it out yet, I'll report if it works when I'm able.
Under IPTV your ISP might be listed to make it easier.
In the 3.0.0.6 firmware there is also a 802.1Q setting on the WAN page
I'm in the UK, I don't think there's any UK ISPs listed.
Yes, but installing the latest asuswrt-merlin makes that disappear, that's the problem that made me ask the question! :)
