Hi everyone!
I'm writing to ask your help, it looks like with Netgear r7800 (even with voxel )is not possible to setup dhcp to send a dns custom configuration. I need this to make lan clients to point to my pihole and the same time make my guest wifi clients able to get an ip address. I was used to use pihole as dhcp but it makes me impossible to use guest wifi if i want it to be separated from the lan.
Any suggestion?
Thank you
Any suggestion?
Thank you
