How to use SmartSync-ASUS Web Storage on ASUS Router
spritezf
Hi, guys! ASUSWRT provide a service called Smart Sync on AiCloud page, this feature allows you to set up a sync rule to sync your data with various provider
Today,let’s talk about how to use one of this function—ASUS WebStorage. Still take RT-AC88U for example.
  1. Login router FW and go to AiCloud 2.0-Smart Sync page to enable smart sync by sliding the button to “ON”, refer to picture 1
  2. Click “Add new account” to set up sync rule and provider, we choose “ASUS WebStorage” there, refer to picture 2
  3. Input your ASUS WebStorage account/password
  4. Click “Browser” to choose a folder path on USB-HDD which pluged in the router
  5. You can choose different sync rule. “Synchronisation/Download to USB Disk/Upload to Cloud” - refer to picture 3
  6. Input “Security Code” if your account support OPT Authentication
  7. Click “Apply” to save the setting
  8. You can check detail error information by clicking “error”- refer to picture 4
  9. Router will auto start synchronizing data after every setting finished, enjoy it.
Before you TURN ON the sync you will not see the added profile for syncing! Very confusing and take me hour to investigate. Hope it helps someone.
Does anybody know hot to set up this OTP? On their site they say
Does it mean that this setting in AsusWRT is irrelevant anymore? Or this concerns only dynamic OTP and there is also some static?
My synchronization is not working for unknown reason, maybe it's because of OTP?
