How would you hook up a Time Capsule, DAP-1522, and DAP-2553
PETERECHS
A friend of mine recently upgraded his hardware and donated his DLINK DAP-2553 to me. The question I have for all of you is what is the best way to use the following hardware:
Apple Time Capsule (Generation 1)
DAP-1522
DAP-2553 (new)
DI-624 (optional)
Currently I have the Time capsule connected to the DSL Modem, with the 1522 acting as a bridge for the DI-624, which is configured as just an access point. I still have the DI-624 because I have some network cams that only work on .11g. If necessary, I can also plug them in via ethernet (to either the time capsule or 1522).
Should I make the 2553 my bridge and then use the 1522 as an access point? Other suggestions?
Thanks,
Peter
You'll get the highest performance if you connect the other APs to the Time Capsule via Ethernet.
If you want to retire the DI-624, you can set either of the DAPs to g-only mode.
