HowTo do not tunnel one client in the network?
verkehrsminister
Hello
how can i setup the RT-N66U that one client doesn t use the tunnel. One Client (IP Adress) should not use the tunnel but should use the normal WAN internet.
The router has a connection as a OpenVPN client to the VPN-provider.
br
Dual Gateway Sabai
Keep an eye on Sabai Technology. They have indicated that they will be releasing a version of their dual gateway software to run N66U very soon.
It will do what you want.
