Tutorial HOWTO use Voxel/Entware/miniupnpd on R7800/R9000 router
arabesc
I've spent some time replacing the stock miniupnpd service to a newer version from the Entware on my R9000. I would like to share my experience with the community.
Requirements:
  • R7800/R9000/same ecosystem router
  • Voxel's firmware
  • Entware
The stock miniupnpd is located at /usr/sbin/miniupnpd, it uses the /tmp/etc/miniupnpd.conf config file that is generated by the /sbin/cmdupnp script.
To replace the stock miniupnpd by the new version from the Entware it's required to:
  • change the /sbin/cmdupnp script to generate a new config and start the new miniupnpd
  • add new chains to iptables where miniupnpd will add its rules
Install miniupnpd from the Entware:
# opkg install miniupnpd
The new version is located at /opt/sbin/miniupnpd
To add the new chains to iptables create the /opt/scripts/firewall_start.sh script with the following content:
Bash:
#!/bin/sh
iptables -t filter -N Forward-UPnP
iptables -t filter -I FORWARD -j Forward-UPnP
iptables -t nat -N NAT-Prerouting-UPnP
iptables -t nat -I PREROUTING -j NAT-Prerouting-UPnP
iptables -t nat -N NAT-Postrouting-UPnP
iptables -t nat -A POSTROUTING -o brwan -j NAT-Postrouting-UPnP
This script will be executed every time firewall settings are changed.
If you are using pppoe/pptp wan-connection then there might be ppp0 interface name instead of brwan. It's possible to automate the logic but I have no way to test it so I've kept things simple.
The chain names (Forward-UPnP, NAT-Prerouting-UPnP, NAT-Postrouting-UPnP) can be arbitrary but they should match the names used in the /sbin/cmdupnp script and further in the /tmp/etc/miniupnpd.conf.
Ensure the /opt/scripts/firewall_start.sh script is executable:
# chmod u+x /opt/scripts/firewall_start.sh
Execute script to apply changes for the first time:
# /opt/scripts/firewall_start.sh
Change the /sbin/cmdupnp script in the following way:
Bash:
SERVICE_PID_FILE="/var/run/miniupnpd.pid"
MINIUPNPD_CONF="/tmp/etc/miniupnpd.conf"
print_upnp_conf() {
cat <<EOF
ext_ifname=$1
listening_ip=$2
port=5555
enable_natpmp=yes
enable_upnp=yes
#force_igd_desc_v1=yes
secure_mode=yes
system_uptime=yes
# uncomment the following option if minissdpd is used on the same system
#minissdpdsocket=/var/run/minissdpd.sock
lease_file=/tmp/upnp_pmlist
bitrate_up=$15
bitrate_down=$16
uuid=<insert your uuid here>
upnp_forward_chain=Forward-UPnP
upnp_nat_chain=NAT-Prerouting-UPnP
upnp_nat_postrouting_chain=NAT-Postrouting-UPnP
clean_ruleset_interval=600
notify_interval=$3
model_number=$11
allow 1024-65535 192.168.0.0/24 1024-65535
deny 0-65535 0.0.0.0/0 0-65535
EOF
upnp_start() {
    local listenip="$($config get lan_ifname) lo"
    local uplimit=$($config get uplimit)
    uplimit=$(($uplimit / 125000 * 1000 * 1000))
    local downlimit=$($config get downlimit)
    downlimit=$(($downlimit / 125000 * 1000 * 1000))
    print_upnp_conf "$wan_ifname" "$listenip" "$($config get upnp_AdverTime)" "$($config get upnp_TimeToLive)" "$name" "$($config get lan_netmask)" "$non_igd" "$(artmtd -r sn | head -1 | awk -F":" '{print $2}')" "$($config get miniupnp_pnpx_hwid)" "$($config get miniupnp_modelurl)" "$($config get miniupnp_modelnumber)" "$($config get miniupnp_modelname)" "$($config get miniupnp_modeldescription)" "$($config get Device_name)" "$uplimit" "$downlimit" > $MINIUPNPD_CONF
    /opt/sbin/miniupnpd -f "$MINIUPNPD_CONF" -P "$SERVICE_PID_FILE" &
Pay attention to the notice <insert your uuid here>, use uuidgen tool or something similar to get your uuid.
The /sbin/cmdupnp script will be reseted after each f/w update. Keeping changes is out of scope of the post.
The format in what the new miniupnpd writes leases to the /tmp/upnp_pmlist file is different from the stock, it will break web-interface a little.
Restart miniupnpd:
# /etc/init.d/upnp restart
Optionally, use upnpclient on another host to test that miniupnpd works:
# upnpc -r 9999 tcp
It should succeed. 9999 is an arbitrary port number, use another port if it's already in use.
The /tmp/upnp_pmlist can be checked for a new lease and iptables for new rules.
