http to https
mantielero
I have a microcontroller (ESP8266). It can make http calls, but not https. I would like to log the data into a google spreadsheet. To do that, I create a script in google so that I can send data like this:
Bash:
curl -L https://script.google.com/macros/s/<my_script_id>/exec?temperature=13
Is there something that I can do with asuswrt, so that I can use a http call from the microcontroller and get the router calling above url instead? I would like being able to do something like:
Bash:
curl -L http://192.168.0.1/exec?temperature=13
Basically you are trying to use your router as a server for a reverse proxy. There should be some packages in Entware that implement it.
But honestly, if it can execute the curl command, why don't you try to use it to log into the router via SSH and then execute the curl command.
To build on @Yota, if you have SSH setup on your router with a key, then from your other client machines;
ssh -p <port> -i <keyfile> admin@IP "exec?temperature=13"
Ripshod Wrong certificate when HTTPS only Asuswrt-Merlin 2
L https connection issue on router Asuswrt-Merlin 8
