CrimsonCleaver
Hi there,
Yesterday I had Hyperoptic install a 1gb connection, I'm in the UK.
I had already bought a Netgear Nighthawk x4S in preparation to try and get as much speed over Wi-Fi.
Currently facing a number of challenges.
Currently have an iMac connected to the router using Ethernet. On the OOKLA Speedtest Mac app (tests in browser were just so unreliable I used the app in the end), I am getting:
Approx 902-910 down
Approx 910-920 up
Which was expected.
Using wi-if on my 2015 MacBook Pro I am getting:
Approx 700-720 down
Approx 530-540 up
Genie app reported link rate:
952Mbps
Which I was pleased with.
iPad Air 2, I seem to be getting:
Approx 410-430 down
Approx 240/250 up
761Mbps
Xbox One S in Edge on OOKLA speedtest, and its own speed test under settings:
165-175 down
761Mbps
Seems pretty slow considering the iPad Air 2 is connected at same rate and getting more than double download speed.
Wi-Fi is all around 15-20 metres from the router, through 2 walls.
These are the problems I am facing:
1) Xbox One S not getting great download speed
The problem I face is this is when using the 5GHz channel 100(DFS), this seems to give me pretty good Wi-Fi speeds on the Apple devices. The Xbox however isn't doing so well.
2) Fire TV and NVIDIA Shield can't connect when on channel 100(DFS)
These devices seem to work better on lower channels, Fire TV on channel 36, but on that channel other devices get slower speeds...
3) Ethernet due to layout of property wasn't really an option for all devices. Especially as Fire TV hasn't got Gigabit Ethernet
Does anyone have any suggestions on hitting good wi-if speeds but ensuring compatibility with devices?
I am also considering buying a second Netgear Nighthawk x4s, and placing in the same room as all my Wi-Fi devices, as an access point. With that, could I assume it can connect at a higher rate to the existing router? And could I connect any gigabit devices to it using Ethernet for speed? (Eg Xbox One)
Approx 902-910 down
Approx 910-920 up
Which was expected.
Approx 700-720 down
Approx 530-540 up
952Mbps
Approx 410-430 down
Approx 240/250 up
761Mbps
165-175 down
761Mbps
