I got something wrong, maybe in Yazfi or Diversion?
JT Strickland
I think I have have a parameter wrong or something. Yesterday I installed YazFi and updated Diversion close to the same time, so that is where I am guessing.
I set up 3 guest networks, but have since disabled them but it didn't help any. I don't think I changed anything in Diversion.
My log is filled with these since installation. Anybody tell me what is going on?
Dec 12 17:04:29 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:29 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:29 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:33 RT-AX86U-CB28 kernel: CONSOLE: 144904.423 wl1: r0hole: tx_exp_seq 0x185, seq 0x186 Dec 12 17:04:33 RT-AX86U-CB28 kernel: net_ratelimit: 41 callbacks suppressed Dec 12 17:04:33 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev wds1.0.1 Dec 12 17:04:34 RT-AX86U-CB28 kernel: CONSOLE: 144905.660 wl1: wlc_recvfilter: bad frame control 0x1d0 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:35 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: net_ratelimit: 95 callbacks suppressed Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev wds1.0.1 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7 Dec 12 17:04:41 RT-AX86U-CB28 kernel: protocol 0800 is buggy, dev eth7
Don't use guest network 1 if you can help it. The "buggy" thing has been documented elsewhere to be tied to guest network 1. As far as I know, it is harmless. Just a nuisance.
If you are using Scribe, you could set up a rule to filter the message out.
Ok, I will leave #1 alone then. I didn't think I had much use for a guest network, but read where others put their security cameras on one, and it seemed like a good idea to me.
And I'll have one for the occasional visitor also.
thanks a bunch,
jts
