İ have weird problem
luzumsuz
When i use isp router i can get 94 mbps on wifi isp router is innboxf60.But when i use rt-ac86u on wifi i can get 66 mbps,on cable no problem i can get 94 mbps also.But when i use vpn 1.1.1.1 warp i can get again 94 mbps on wifi.And when i use asus with isp router im still get 66 mbps on wifi.Over 3-4 years i cant handle this.I use fiber converter have 100mbps port with asus.
I can see you're not happy with the performance of the RT-AC86U, but you need to give more details and ask specific questions if you expect a reply.
What is your ISP paid-for speeds? What is your ISP supplied modem/router? What is your connection type?
What firmware are you running on your RT-AC86U? What VPN are you using? What steps, if any, have you taken to increase the performance of the VPN?
Over 3-4 years? I don't think the RT-AC86U has been out that long?
My isp is Vodafone in Turkey.My connection type is fiber ftth.Isp router innbox f60.Im paid for 100 mbps.384.14_2 Firmware which is router use.Im just use 1.1.1.1 app on iphone x.that im say vpn is not actually if am not wrong know and i buy rt-ac86u in 2017 so not over 4 years 3 years.https://www.speedtest.net/my-result/i/3675310683 Multi
https://www.speedtest.net/my-result/i/3675311643 Single
https://www.speedtest.net/my-result/i/3675487901 1.1.1.1 Warp
