I want to use a dual band USB adapter while in the apartment and request anyone having experience making such a change for advice. I already have the following dual band USB 2.0 adapters which have listed on the packages as Windows 7 Compatible:
Linksys AE1000v1
Netgear WNDA3100v2
Trendnet TEW-664UB R2
I have the following concerns:
I read the thread Replacing a Laptop's Built-in WiFi Adapter by Bulldog on page 20.
In responses to Bulldogs inquiry the community recommend disabling the internal wireless adapter in the device manager, unchecking the box on the proprietary wireless management tool and checking the box selecting the windows wireless management tool. Then installing the USB adapter and driver. There was no discussion about using the wireless management tool supplied with the USB Adapter. Does the Windows 7 wireless management tool show all SSID's when there are several Access Points with the same SSID at a location like when in a hotel or does it show only one SSID like the Windows XP management tool did?
If both wireless management tools, check boxes, in a computer are left unchecked can the proprietary wireless management tool supplied with the USB adapter be installed without corrupting the operating system?
Will a USB adapter provide the same range in the 2.4 GHz band as the computers internal Wi-Fi adapter or would there be a quick way to switch between the USB adapter and internal Wi-Fi adapter when I am at the house?
