Vampiry_Yazo
Hi Network Builders,
I have recently bought a Blue-Ray Player which came with various apps on it like Netflix, YouTube etc. Now, to either update its firmware or use the mentioned services I need to connect it to the router, the only problem is that the Blue-Ray Player only have LAN port available for internet connection and is located in another room.
Is there a way that I can convert RJ45 to Wi-Fi ? I need something cheap & small. I was thinking about buying a mini travel router (TP-Link TL-WR902AC) then connecting the said player into it and switch it to client mode which will then connect to my Wi-Fi.
Any recommendations ?
Vampiry_Yazo
Vampiry_Yazo
