1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
id command in Asuswrt-Rmerlin
Discussion in 'Asuswrt-Merlin' started by Denna, Mar 19, 2017.
  1. Denna
    Denna Senior Member
    Aug 4, 2016
    296
    Is there a command similar to "id" in Asuswrt-Rmerlin that displays uid, gid and groups ?
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. ColinTaylor
    ColinTaylor Part of the Furniture
    Mar 31, 2014
    5,162
    UK
    Not that I'm aware of. It would be fairly pointless because the OS isn't designed to be a multiuser system. That's why there is no useradd, userdel, usermod, groupadd, groupdel, etc.
  4. Denna
    Denna Senior Member
    Aug 4, 2016
    296
    @ColinTaylor,
    So you can't create accounts for Entware applications like unbound and dnscrypt-proxy to not run under admin ?
    Unless there's a way to create accounts natively, the alternative is to install the Entware package of busybox.​
  5. ColinTaylor
    Mar 31, 2014
    5,162
    UK
    Sorry I don't use entware so I can't comment on that. If you want a multi-user Linux system I think you'd be better served by using something like a Raspberry Pi. I think others have setup a chrooted Debian environment on the router.
