IGMP Snooping kills MacBookpro Wifi
Ditch
Why the hell if I enable IGMP snooping on 5GHz my macbookpro get disconnected every 5 minutes?
L&LD
Part of the Furniture
Relevant details missing.
EmeraldDeer
Does the behavior change if IGMP proxy is enabled?
sfx2000
IIRC there are multiple places to enable/disable the IGMP stuff - for Apple devices, disable IMGP Snoop/Proxy in the Wireless (Professional settings), and you should be fine.
Depending on the firmware version and model, there is a place to enable IGMP snooping for the LAN switch (ethernet), and it's safe to enable it there.
