In consternation - new firmware
mario-sz
Pardon my English, but seeing the new Asus firmware, I'm terrified that the device should be reset to factory settings after the new update.Many people say that the AX58u and others are consumer-grade routers, etc., but that's not entirely true, as they were recommended for small businesses https://www.asus.com/microsite/better-wifi-for-smb/ for years.
Does anyone really think that when the new firmware comes out, it will be restarted with six mesh points in different locations?
Someone must be crazy to want to configure everything for me. That's why I have a backup! And I read that I can't use this backup.
... I'm terrified that the device should be reset to factory settings after the new update.
Why does resetting the router terrify you? Asus has explained why they suggest resetting the router. To apply new firmware security settings and changes. It is your choice to do so, or not to do so after you flash the new firmware. It is also your choice if you want to keep those new reset default router settings or change them to match your use case.
A router reset, to restore a router back to firmware default values, is a common process to perform for a number of valid reasons. There is nothing to be scared of. Just record any changes you made to the default settings of your router before updating and resetting the router, then manually apply those changes after the firmware update and reset.
Hi. Thank you for your reply, but I disagree that this is standard practice. I also use a SonicWall 3700 at my company, and I can't imagine having to reinstall everything after a firmware update, as I'd have to shut down the company for a week. Firewall rules, NAT, objects, etc., aren't something you can implement in an hour or two.
It is a recommendation not a requirement that you perform a factory reset after updating the firmware. That recommendation is a blanket statement from Asus to cover all routers, in all circumstances, for users of all skill levels. You decide whether or not it is appropriate to do a factory reset on your devices.
Note that the recommendation appeared shortly after a recent security vulnerability resulted in malicious code being placed on the router. The fastest way to remove that code is to do a factory reset. Just installing a new firmware image will not do that. Your average user is not going to be able to SSH into the router, navigate the filesystem and identify code that shouldn't be there.
As you appear to be more than capable of securing your router (e.g. not enabling AiCloud or web access from WAN) I see no reason for you to do a factory reset. But as always check the firmware release notes for any specific requirement, e.g. moving from firmware branch 386 to 388.
THX ;)
Just let your devices upgrade themselves. Nothing in the operation will change. This is my plan as I disagree with the password policy. I recently canceled a medical portal because they were forcing a 12 digit password.
You are free to disagree, but it the reality and fact that many router manufacturers include the capability (even sometimes recommend) resetting their equipment to default for various reasons, particularly as a troubleshooting step if one is having issues. In this case Asus, for their own reasons, are recommending it to ensure the security updates are correctly applied post firmware update. As already indicated, you have the choice of performing the Asus recommended factory reset to apply the new security settings or not after firmware update. There has been discussion in other recent firmware Release topics in this subforum discussing this Asus firmware reset request with people making similar objections to your own. Do it or don't, your choice.
