Hi Everyone,
Ive been lurking around here for a while, trying to learn what I can (boy is there a lot and boy do I have a lot to learn). I'd like to thank everyone for their various contributions in advance.
I'm currently in the market for a new router. Previously I have used a variety of different devices, most recently and airport extreme, Im tech savvy but not well versed in networks specifically.
A few years ago I moved from a house at 2000 sq ft to an apartment at 837 sq ft. When I first moved in I had a modem that fed my router (The AirPort Extreme), however that was soon "upgraded" by my provider to a modem/router all in one (required to get the faster speeds, cable and DOCSIS3 vs DOCSIS2). Ive been using it ever since, but it is less than stellar. To complicate things, being in a high-rise environment I can see over 30 plus wireless networks at any given time. Its crowded to say the least. Also the building is concrete and in-between the apartments in reinforced by security mesh as well as 2 layers of drywall.
Most recently Ive moved away from my desk top iMac to a new MacBook Pro. This has created the complication of using Time Machine back ups. Since the computer is seldom plugged into the drive, it can go a long time without backing up. This I would like to avoid by using the over the air ability of Time Machine. Unfortunately the USB ports on my providers Modem/Router are disabled and cannot be disabled, they can put it into bridge or IP Passthrough. My first thought was that I would just use the AirPort Extreme again, however it os getting long in the tooth and I thought that I would start exploring the options. This, it would appear is mistake one. In any event, things that interest me are QOS and Parental Controls as well as security. The last one is important as my wife is now pregnant (read we are pregnant) and we plan on using IP based cameras for "baby monitors" but we don't want them compromised. I have a very large budget to throw at this, so money isn't the problem, but obviously I don't want to overspend if Im not going to see any benefit.
Network devices as follows:
Cable (Shaw in Canada) -> Hitron CGNM-2250 Advanced WiFi Modem -> New Router
Wired Connections:
Apple TV (4th Generation)
Android Kodi streaming box (proprietary M8ish box, BlackstreamTV.com
USB 2 X inexpensive bus powered 1tb hd's for backups of MacBooks
Wireless Connections:
Macbook Pro 2017 (mine)
MacBook Pro mid 2014 (wife)
iPhone 6 (wife) (probably upgraded soon)
iPhone 7+ (mine)
iPhone 5s (to be used as baby monitor)
iPad Air (mine)
iPad Mini4 (wife)
3X iHome IW3's scattered around the apartment for air playing music
Wireless Printer HP-1102 LaserJet
Likely 2 or 3 nest cameras.
Likely a nest thermostat.
TV also connects via wireless but don't use it for anything other than firmware.
Ive previously used net-gear products: Originally drawn to the Nighthawk H6X R800P due to its intelligent load sharing, but then looked at the R8500 which seems to have QOS but looses the extra off load processors it has less antennas but seems to be a better shape for where I would place it... Then looked at the R9000 and got really confused. Looked at the Synology RT2600, then like everything from ASUS then the RT-AC68U as it can firmware changed, but then I got worried about using open firmware.
All of that to say, I was wondering if you guys could point me in the right direction.
Thanks again in advance!
Stephen
Wired Connections:
iPhone 7+ (mine)
iPad Air (mine)
iPad Mini4 (wife)
Stephen
