Incorrect behavior of Asuswrt-Merlin and inability to restore stock firmware on Asus RT-AC66U B1
network_user1
Hello.
I need help and advice on how to recover my router. I am not a hardware engineer or network administrator — just a regular user.
1. Background
About a year ago someone gave me a non-working ASUS RT-AC66U B1 router (I also own another RT-AC66U B1 running FreshTomato, that one works fine).
The "broken" router behaved like this:
  • LEDs reacted to cable insertion in every port except LAN2
  • The router did not establish network connections
  • When connecting it to other routers, the link speed was detected incorrectly
  • (10 or 100 Mbps instead of 1 Gbps), or there was no link at all
  • Wi-Fi did not appear
  • It could not enter Rescue mode — Power LED did not flash
At that time I gave up on it.
2. Recent progress
Recently I found it again while sorting old equipment and decided to power it up. Surprisingly, it booted — slowly, but it worked.
I reset it to factory settings (because I didn’t know the passwords) and upgraded the firmware from Asuswrt-Merlin 386.12 to 386.14_2 (with full reset)
Router now:
  • boots and operates
  • Wi-Fi networks appear
  • routing under load works normally
  • CPU temperature stays around 58–62 °C (under normal load)
But:
  • port LAN2 is still dead
  • Merlin firmware uses only one CPU core instead of two (visually confirmed in System Monitor and via /proc/cpuinfo)
ASUSWRT-Merlin RT-AC68U 386.14_2 Sun Nov 17 19:17:59 UTC 2024
admin@RT-AC66U_B1-C780:/tmp/home/root# cat /proc/cpuinfo
Processor       : ARMv7 Processor rev 0 (v7l)
processor       : 0
BogoMIPS        : 1998.84
Features        : swp half thumb fastmult edsp
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x3
CPU part        : 0xc09
CPU revision    : 0
Hardware        : Northstar Prototype
Revision        : 0000
Serial          : 0000000000000000
3. Goal
I want to restore stock ASUS firmware (the official firmware for this model still receives updates in 2025) and hopefully get both CPU cores working properly again.
4. Recovery attempts
I successfully enter recovery mode (the power LED is blinking):
ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=3ms TTL=100
TTL=100 → recovery mode, correct.
Downloaded the official firmware RT-AC66U_B1_3.0.0.4_386_52062-g06fe188.trx . Renamed it to: asus.trx
Attempt #1 — Asus Firmware Restoration Tool
Result: “The wireless router is not in rescue mode.” Even though Power LED is flashing and ping says TTL=100.
Attempt #2 — CFE MiniWeb Server
When opening http://192.168.1.1 (Firefox, Microsoft Edge) I get: ASUSTek – CFE miniWeb Server. But after selecting the firmware and pressing Upload, the browser loads for a while and then URL changes to: http://192.168.1.1/f2.htm "The connection was reset while the page was loading"
I waited 10–15 minutes, rebooted manually → still boots into Asuswrt-Merlin.
Attempt #3 — TFTP upload
Reply from 192.168.1.1: bytes=32 time=1ms TTL=100
Reply from 192.168.1.1: bytes=32 time=2ms TTL=100
Reply from 192.168.1.1: bytes=32 time=4ms TTL=100
4:55 tftp -i 192.168.1.1 put asus.trx
5:05 Transfer successful: 106954772 bytes in 592 second(s), 180666 bytes/s
After upload:
  • Power LED turns off
  • LAN1 LED flashes very fast
  • No response to ping
ping 192.168.1.1
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.1:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
I waited 20-30 minutes. After manual reboot → Merlin loads again. I tried this method few times.
5. Question
What else can I try to successfully flash the stock firmware?
Any guidance or suggestions are appreciated.
Thank you.
Below are the logs from the router web UI after factory reset and reboot.
I can't post the logs. Attaching a file doesn't post the file to the thread. And trying to post a comment with the log text returns an error:
Oops! We ran into some problems.
Oops! We ran into some problems. Please try again later. More error details may be in the browser console.
I posted logs here 👉👉👉👉👉: https://pastebin.com/eF2Yg7qS
