Turgut Kalfaoglu
Hi.. I installed entware on my AC68U following the
https://github.com/Entware/Entware/wiki/Install-on-Asus-stock-firmware
installation guide.
However now many commands complain of missing libc.so.6 like ipkg and named and transmission Any ideas?
example launch:
s# /opt/etc/init.d/S50downloadmaster start
cat: can't open '/tmp/dm_mount_path_n': No such file or directory
check DM2 start
dm2_ipk is OK
check DM2 end
killall: dm2_transmission-daemon: no process killed
killall: dm2_amuled: no process killed
killall: dm2_nzbget: no process killed
iptables: No chain/target/match by that name.
iptables: Bad rule (does a matching rule exist in that chain?).
./dm2_nzbget: '/opt/lib/libstdc++.so.6' library contains unsupported TLS
/opt/bin/dm2_amuled: '/opt/lib/libstdc++.so.6' library contains unsupported TLS
./dm2_transmission-daemon: can't load library 'libc.so.6'
/opt/bin/dm2_amuled: can't load library 'libc.so.6'
./dm2_nzbget: can't load library 'libc.so.6'
/opt/bin/dm2_amulecmd: '/opt/lib/libstdc++.so.6' library contains unsupported TLS
/opt/bin/dm2_amulecmd: can't load library 'libc.so.6'
cat: can't open '/tmp/asus_router.conf': No such file or directory
check asuslighttpd start
asuslighttpd_ipk is OK
check asuslighttpd end
killall: asus_lighttpd: no process killed
./asus_lighttpd: '/opt/lib/libc.so.6' library contains unsupported TLS
./asus_lighttpd: can't load library 'libc.so.6'
turgut@RT-AC68U-75C8:/jffs#
installation guide.
example launch:
check DM2 start
dm2_ipk is OK
check DM2 end
