Installed Voxel but issue with no internet
jig
Hi guys,
I followed kamoj steps and have installed voxel and get the kamoj and hidden menus (thanks), but now I cannot access the internet the router and virgin are showing internet is ok (light). when I click on a webpage I get 'establishing a secure connection' and it does not connect? also internet through wifi has stopped working.
Also I struggled to get a VPN set up (using NORDVPN) on the VPN menu, do i need to do or add some details? I have done a reboot of the modem (virgin) and the router but no luck!
can someone please help?
kamoj
Look at the add-on router information page for errors.
Check if ping is working:
ping 1.1.1.1
You can not setup the kamoj add-on VPN without internet.
So disable DNS encryption and VPN.
jig
thanks Kamoj. I also got the following error when i first tried to set up and add the Nord VPN server:
--2020-06-28 12:00:09-- https://downloads.nordcdn.com/configs/files/ovpn_legacy/servers/fr425.nordvpn.com.udp1194.ovpn
Resolving downloads.nordcdn.com... 2606:4700::6811:a81e, 104.17.168.30, 104.17.167.30
Connecting to downloads.nordcdn.com|2606:4700::6811:a81e|:443... failed: Network is unreachable.
Connecting to downloads.nordcdn.com|104.17.168.30|:443... connected.
ERROR: cannot verify downloads.nordcdn.com's certificate, issued by 'CN=Sectigo RSA Domain Validation Secure Server CA,O=Sectigo Limited,L=Salford,ST=Greater Manchester,C=GB':
Unable to locally verify the issuer's authority.
To connect to downloads.nordcdn.com insecurely, use `--no-check-certificate'.
open error
[email protected]:/etc/openvpn/config/client#
jig
Please see screen shot attached... cannot see any issues?
kamoj
I don't have NordVPN account so I can not check myself.
That picture is too small to readable for me.
Get internet working first, before trying VPN.
jig
internet not working I have reset my modem (it works)and connect it to netgear router and then it doesnt seems to be a problem/config between modem and netgear router, any ideas. Only stopped working after i installed voxel. (I have done a hard reset on the modem and router (still have kamoj and hidden installs available). thanks
Thang
gg trans
There are a few cases of losing internet connection after changing DNS but we don't close the r7800 setting tab in web browser, I have encountered it many times and found out.
jig
guys started again and redid, still get the following error, any ideas what is going on???
--2020-07-05 22:14:50-- https://downloads.nordcdn.com/configs/files/ovpn_tcp/servers/de723.nordvpn.com.tcp.ovpn
Resolving downloads.nordcdn.com... 2606:4700::6811:a71e, 104.17.167.30, 104.17.168.30
Connecting to downloads.nordcdn.com|2606:4700::6811:a71e|:443... failed: Network is unreachable.
Connecting to downloads.nordcdn.com|104.17.167.30|:443... connected.
open error
kamoj
Don't know what you are up to.
Those logs are not from the kamoj add-on.
I don't think Voxel or Kamoj has anything to do with what you do.
I strongly suggest you to use the kamoj add-on "OpenVPN Client".
Once you understand how it works you can try your way.
jig
Hi guys,
Im at a loss here as to what is going wrong. I can ping 1.1.1.1 but when I connect to wifi using netgear it doesnt seem to connect to the internet and seems like something is blocking?
I have done several reboot cycles to try and fix but no joy. The virgin router is fine it seems to be a setting on the netgear, any ideas? (the voxell software and kamoj add on software has installed ok and can be seen).
Jig
kamoj
Your Virgin modem should be in NAT/Bridge/Pass-through mode if you connect a router to it.
Rustypouch
Hey Jig, I am using a Super Hub 3 with Virgin Media, through a R7800. Do you have the Super Hub running in Modem Mode?
jig
Hi Rustypouch,
you have the same setup as me. So to confirm Virgin Superhub is in modem only mode. I can see 7800 home page showing internet status as 'Good', however when I click on explorer or chrome cannot open the web page, so something is blocking? can you help?
I have reset the 7800 and superhub and still no joy :(
jig
Hi Rustypouch,
