installing rmerlin latest firmware
chrisnasah
Can anyone confirm which is the latest version of rmerlin firmware?
Also is it a simple case of going to admin and uploading image from there?
can it be done wirelessly?
There's a sub-forum dedicated to Asuswrt-Merlin here on SmallNetBuilder. Take a look there, you will find all of these answers there - start with the sticky at the top.
You should not upgrade firmware using a wireless connection, you should always use a hard-wired connection to the router to do that. So, for example, if you only have a laptop that's wireless, you would connect an ethernet cable between the laptop and the router and use that for firmware upgrade.
