Intel 9260 Wireless behaviour
steve_togo
I had an intel 8260 wifi card on a gigabyte PCIE card for my desktop. Recently i was having issues where 5 ghz was not visible or not working. I replaced the card with a 9260 and i stgill have the same issue.
The weird thing here is I can see other 5 ghz networks and connect to it if i use a different router (Wifi + Modem) combo.
My primary AP is TP-Link EAP 225 and I cannot see the 5ghz broadcasted by these AP's. The 5 Ghz network from this ap is visible on my phone but not on my PC using intel 9260. I have done the following.
1. Deleted drivers and updated multiple times
2. Created a spearate 5ghz network, changed security settings to include no security.
3. Rebooted multiple times.
4. Reset the AP
Still no luck. I would appreaciate if there is any insight on this issue.
Thanks!
Right now I have 2 AP's and they are on channel 161 and 48. Interestingly I can now see and connect to 5ghz network but not to the one from my AP. I checken my WLAN report and I have the following error.
EventId Time Message
8000 2019-07-10T16:14:59
[‒]WLAN AutoConfig service started a connection to a wireless network.
Network Adapter: Intel(R) Wireless-AC 9260 160MHz
Interface GUID: {2ccab899-0808-4370-a195-75c52008a202}
Connection Mode: Connection to a secure network without a profile
Profile Name: t1a
SSID: t1a
BSS Type: Infrastructure
8002 2019-07-10T16:14:59
[‒]WLAN AutoConfig service failed to connect to a wireless network.
Profile Name: t1a
SSID: t1a
Failure Reason:The specific network is not available.
RSSI: 255
Do they have a selective channel that it works against?
I was asking to see if you were using a DFS channel. You are not.
Did the 8260 card ever work with the TPLink AP? If yes, what changed?
What version EAP225 are you using?
What is the make/model of the AP/router that the card connects to?
Yes it was working with 8260 fine before.
My AP is EAP 225 -v3 and ER-X is my router.
Today i was able to connect to the AP only if i roll back the driver to 20.120.1.1 and set my 5ghz property on my AP 80 Mhz only. It does not work if i set it as 20/40/80. Also the connection rate is super low. It is not going more than 173.3 mbps
Which router it this that you say works?
But you started this thread by saying:
So what happened to make the 8260 have "issues"?
173.3 Mbps link rate indicates 20 MHz bandwidth operation
Have you tried changing any 9260 settings in its Wireless Properties?
Disable MU-MIMO on the AP if you can.
Its working with an SBG 6700 AC
8260 worked fine for more than a year and I replaced the card with a 9260 thinking the issue was card. Anyways I would like to use my 9260 now and I contacted inte, they wanted me to recah out to Dell to see if they had a driver for me. I use an optiplex 7040 and does the system or the processor matter here?
I tried changging a couple of settings on the AP as well as the card.
Forcing 5 ghz
Auto channel selection
etc.,
Please let me know if you would like me to look at something specific.
Thanks!
