Solved Setting tokenised IPv6 identifiers by user script
roxxor
I succesfully configured Unbound but, as I'm now playing with IPv6, I would like to use tokenised IPv6 identifiers with "ip token" command. Can someone please direct me as I'm unable to identify which user script to use to add this command. I tried init-start but it seems to be way to soon in the startup process, I created own script with exactly same content and it didn't run so I'm kind of stuck there.
Thanks.
Self answer, just create new executable file in /jffs/scripts folder with (example below to have the LAN interface IPv6 address on my Asus XT8 begining with my network prefix and ending with fixed ::2 suffix):
#!/bin/sh
ip token set ::2 dev $(nvram get lan_ifname)
