Herman Slotenmaker
Hi all,
my current situation: one main ac-86U aimesh router and one ac-68U aimesh router. Ethernet backhaul. (yes I ditched the Lyra's).
No smartconnect. Seperate networks: wifago-24; wifago-50 and wifago-guest-24. Latest ASUS firmware.
For about a month or so I am experiencing wifi-issues. App's loading really slow. Internet disconnecting, etc.
When changing to the 5GHz band, issues dissappear instantly. So issues seem limited to 2.4Ghz band.
What could be problem? In the log noting that stands out?
Log seems to be flooded with these:
Oct 2 16:39:56 wlceventd: wlceventd_proc_event(527): eth5: Auth C2:73:04:C2:B2:A2, status: Successful (0), rssi:0
Always same mac address. Looks like the Ipad from work..
And I noticed the wifi channel changes very frequently (every 20 min or so). But there is virtually no interference of neigboring networks. Only both aimesh routers.
And quite a lot of entries on my open VPN server:
Oct 2 16:52:47 vpnserver1[2543]: 190.123.83.140:53 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Oct 2 16:52:47 vpnserver1[2543]: 190.123.83.140:53 TLS Error: TLS handshake failed
Oct 2 16:52:47 vpnserver1[2543]: 190.123.83.140:53 SIGUSR1[soft,tls-error] received, client-instance restarting
But I am not trying to acces the vpn server..is this someone trying to acces my vpn server? should I be worried?
So two main questions:
1. what could caus the wifi issues?
2. What can be done about them.
Kind Regards
HaMPeL
Kind Regards
HaMPeL
