Internal routing issue with RT-AC66U
toxaris
Hello.
I have quite complex network at home.
And I have a strange routing behavior.
I have done a map of my network for you to look at.
This picture here (OneDrive)
This works for example:
-Infra01 can reach all clients in the network.
-Client1 can reach all clients in the network.
-RT-AC66U can reach all clients in the network.
-All client have internet access.
This does not work:
Client2, Client3, Infra02, Infra03 only reach clients on the 192.168.1.0 and 192.168.2.0-network but cant reach any clients on 192.168.0.0-network except RT-AC66U (192.168.0.1).
In other words, there is some strange issue when clients on ether 192.168.1.0 or 192.168.2.0-networks try's to reach anything on 192.168.0.0 network except the gateway RT-AC66U (192.168.0.1).
If I do a tracert from Client1 (192.168.0.2) to Client2 (192.168.2.2) it ends up with three hops. Working as expected.
1: RT-AC66U (192.168.0.1)
2: Infra01 (192.168.0.82)
3: Client2 (192.168.2.2)
But if I do a tracert the other way around, Client2 (192.168.2.2) to Client1 (192.168.0.2), I get this.
1: Infra01 (192.168.2.1)
2: Timeout
3: Timeout
What is wrong here?
my guess is that the routing table one Infra01
It shows 192.168.2 as being on Nic2
But in your diagram you show 192.168.2 as being on Nic3
Very impressed with your network map, which program did you use to create that?
As for the question; does setting up Static Routes on the RT-N66U solve these issues for you?
Go to LAN and click the Route tab to setup Static Routes.
@phibertron, it might be confusing. But the Hyper-V host have 3 NICs. But the NIC 1,2 and 3 isnt the same number as its Internal Hyper-V Switch.
Hyper-V Host Configuration.
NIC 1: 192.168.0.10/24 (Management NIC)
NIC 2: 192.168.0.82/24 (Bound to Hyper-V External switch "External 1")
NIC 3: 192.168.2.1/24 (Bound to Hyper-V External Switch "External 2")
And by the way, dont get confused but the naming convention on the Hyper-V switches.
In Hyper-V there is three types of virtual switches, External, Internal and Private. That's why they are named like this.
Internal = Both the virtual machines and the host is connected to this virtual switch bound to the same NIC. Some sort of bridge so to say ;).
External = Bound to its own physical NIC only.
Private = A virtual switch that isn't bound to any physical NIC and cant talk to the host.
@L&LD, I made the map by hand in OneNote actually ;)
There is two static routes on RT-AC66U:
Network NetMask Gateway Metric Interface
192.168.1.0 255.255.255.0 192.168.0.82 5 LAN
192.168.2.0 255.255.255.0 192.168.0.82 10 LAN
If I for example remove those routes, then clients on 192.168.0.0 cant ping clients on 192.168.1.0 or 192.168.2.0 networks. So I believe these are correct.
OneNote, cool!
Sorry, I got mixed up and thought you were running the N66U. RT-AC66U it is.
If you add a static route to 192.168.0.2, does it work?
OneNote, cool!
Hmm, interesting thought. I'll try that just to se what happens.
@L&LD, actually, if I put in this route on RT-AC66U Client2 (192.168.2.2) can reach Client1 (192.168.0.2).
Network Networkmask Gateway Metric Interface
192.168.0.2 255.255.255.0 192.168.0.1 2 LAN
So, this solves it for you?
If I'm not mistaken, Static Routes are one way by default, if you need access both ways then you need a rule for each.
Well not realy, cos now I can only reach 192.168.0.2 from clients on 192.168.1.0 and 192.168.2.0 networks.
So thats more of a workaround to reach on client.
One interesting thing is that now with this configuration the traffic doesn't hop on RT-AC66U.
If I do a tracert from Client2 (192.168.2.2) to Client1 (192.168.0.2) thers only two hops.
2: Client1 (192.168.0.2)
Should there be three hops?
Like This.
2: RT-AC66U (192.168.0.1)
3: Client1 (192.168.0.2)
I think that's the switches doing their jobs.
But now that I look at it closer, can you put a Static Route on the Hyper V Host?
Yes, Infra01 is a Windows 2012 R2 server that acts as the router.
I have installed RRAS and enabled IPv4 routing. That is basically what I have done so far.
