Internet Access for the Router/Entware in "AP" mode?
cloneman
I'm debating between the official "AP" mode and the DIY mode, (disabling DHCP and NAT, making a LAN-LAN wired connection, leaving WAN port vacant).
After years of using AP mode I'm giving DIY mode a try, but I can't figure out how to give the router internet access for its internal use (e.g. entware apps). If the Wan port is disabled, is it possible for the router to have internet access?
Any comments on how "AP mode" really works are also welcome. The reason I'm doing down this path is "AP mode" hides a lot of the menu options (such as VPN) which I might want to try using somehow.
You will not be able to use Entware in AP mode. AP mode requires you to connect to the WAN port from a LAN port on a router or switch.
If I had a 2nd ISP I could do this easily, the problem is I can't set my WAN on the same IP subnet as my LAN the way I'd want to.
I figured it out!
Step 1
Set a static route to tell the router where to go (my Main router is 192.168.7.1)
Step 2
add dnsmasq custom configuration for a DNS server of your choice
cat /jffs/configs/dnsmasq.conf.add
server=192.168.7.1
Running Entware is not dependent on being in router mode so it can work in AP mode.
Not necessarily. In AP mode the WAN port becomes just another LAN port so any of the ports can be connected to the upstream router or switch.
