internet status
mruk30
I have a problem with WAN main connection satus. It shows disconnected but actual internet is working. What could be the reason for this. Can anyone help?
Does it work when you have the GUI in English?
(after a reboot)
This is the same situation from the day one when you bought the router?
When it started? Do you remember that moment?
I my case this kind of questions helps. Hope it helps you too.
Good luck!
Go to Administration > System > Basic Config and turn off Network Monitoring.
If you have enabled a VPN client try turning it off.
Try setting the WAN DNS Setting to 1.1.1.1 and 1.0.0.1 (or the DNS servers you prefer).
Make sure you reboot afterward (and check the settings stick).
Have you tried clearing the browser cache?
