Internet trafic through VPN
NickoP
Hi all,
I need some help with Internet connection through VPN.
In RT-AC68U I setup VPN through asuscomm.com and in Win7 successfully established connection with it. Is it possible to direct the Internet traffic through the VPN? How do I instruct the browser to do this?
Hi all,
as far as in the router settings....the "asuscomm.com" is the dynamic dns service....not a VPN service..
Anyway, you can enable the VPN feature in the router settings....how it works depends on what type you use...OpenVPN or PPTP. I use OpenVPN and their client software does everything for you.
If you successfully connect remotely from a client machine....then it should automatically be directing traffic through the new interface. The browser has nothing to do with it....the operating system does. The VPN connection should say "Internet Access" when you view the connections properties.,,,if not..then there is some configuration issue.
