Read some passing comments about this issue, but no threads specifically about it.
Starting about 380.64, I can't admin my rt-n66u from my iPad because it crashes the browser regularly. First time it happened I just figured it needed a reboot. I have several computers I can use if I really need to connect, but it's much more convenient sometimes to use an iOS device. To be clear, I can always get to the login page, but after logging in, all bets are off in terms of stability.
Things I've tried:
- rebooting the router. No effect.
- rebooting the device. No effect.
- updating firmware. Latest was 380.64_2. No effect.
- clearing all browsing data (cache) in safari. This sometimes lets me get logged in, but will crash in fairly short order. Also, the widget in the right rail is always a white hole in the page. Maybe that has something to do with it?
- Chrome. This let me connect and see the entire status page, but after a couple of clicks (taps), it crashes. Sometimes the menu is missing. Sometimes only part of the page is visible.
- Firefox. This let me connect as well, but then the screen usually goes gray and I can't see anything.
This used to work very reliably. I could do anything from iOS that I could do from a desktop browser (even update firmware - I know it's not recommended, but it worked). Not sure exactly when this started (thinking 380.64), or why it's every browser on my iOS devices (do they all use the same web page rendering under the hood?)
Any suggestions on workarounds or how I can gather more info to troubleshoot?
Thanks for any help
Things I've tried:
Thanks for any help
