YazFi IP Address Assignment in YazFi - Only under Guest Subnet? Or also in Regular LAN?
abracadabra11
Do YazFi connected clients get both a guest network subnet IP address and a regular LAN IP address? I expected that wasn't the case, but I'm seeing what I regard as strange data in the YazFi connected clients section and Wireless Log.
HOSTNAME IP ADDRESS MAC
XXXXXXXXXXX 192.168.68.206 192.168.2.26 XX:XX:XX:XX:XX:XX
AAAAAAAAAA 192.168.2.163 XX:XX:XX:XX:XX:XX
BBBBBBBBBBB 192.168.2.57 XX:XX:XX:XX:XX:XX
CCCCCCCCCCC 192.168.2.136 XX:XX:XX:XX:XX:XX
XX:XX:XX:XX:XX:XX
XXXXXXXXXXX
192.168.68.206
XX:XX:XX:XX:XX:XX
AAAAAAAAAA
192.168.68.126
XX:XX:XX:XX:XX:XX
BBBBBBBBBBB
192.168.2.57
XX:XX:XX:XX:XX:XX
CCCCCCCCCCC
192.168.68.45
I want to be clear that I don't think there's a problem with YazFi - I'm just trying to understand how it SHOULD work. As you'll note in my signature, my AIMesh Node is running 386.1, so the IP assignment to the regular LAN may very well be because of the Guest network extension in AI Mesh 2.0 and some incompatibility with 384 (which I'm still running on my main router). I plan on upgrading the main router to 386 once all the scripts I use have been updated to support it.
