IP addresses logging on to router
leehebs
I was in the loft checking my home server which my anti virus had stopped 75 hi jacking viruses loading , so I decided to check the router logs. I found about the same amount of log in attempt log ins on my router from address such as these. I did a whois trace and they came back to hosting firms in the states and Canada, so have I been hacked, attacked. I changed passwords and the anti virus software stopped the viruses loading. anything else I can do. thanks for any help
Dec 18 00:19:07 HTTP login: Detect abnormal logins at 30 times. The newest one was from 107.150.38.106.
Dec 18 00:19:09 HTTP login: Detect abnormal logins at 35 times. The newest one was from 107.150.38.106.
Dec 18 00:19:10 HTTP login: Detect abnormal logins at 40 times. The newest one was from 107.150.38.106
ec 14 21:11:23 HTTP login: Detect abnormal logins at 5 times. The newest one was from 205.204.90.125.
Dec 14 21:11:27 HTTP login: Detect abnormal logins at 10 times. The newest one was from 205.204.90.125.
Dec 14 21:11:34 HTTP login: Detect abnormal logins at 15 times. The newest one was from 205.204.90.125.
Dec 14 21:11:39 HTTP login: Detect abnormal logins at 20 times. The newest one was from 205.204.90.12
Disable WAN Access to your router, under System -> Administration.
