Morrison5891
OK, I am about to install 8 Cisco PVC2300 ip cameras using POE.
My question is this ....
I will be connecting this cameras to a Linksys SRW224P - 24 Port PoE Switch w/ 2 Gigabit Ports & WebView
I Think the Linksys router will supply 15.4W simultaneously on 12 ports
So, each cam requires 10w - This should be more then enough to power the cameras, right? I just need to make sure this is correct before I buy this hardware. Also, my other question is this... Once the cams are connected to the switch... how would I assign the IP address to each camera and forward ports so I can monitor all 8 cameras with the software I choose to watch these cameras? The software will be installed on a Windows Vista machine 64 Bit
Thanks for any help!!
