Carnagerover
Just a quick question, I went into my router log tonight and it is full of DHCP requests from iPads and iPhones. Will this have a negative effect on the router, should I give them all static ip addresses?
Giving iphones and ipads static ip's will not change the DHCP requests from them. It's normal for apple products cause I think iphones, ipads, ipods, ...etc are designed to disconnect the wifi when on standby to conserve battery.Just a quick question, I went into my router log tonight and it is full of DHCP requests from iPads and iPhones. Will this have a negative effect on the router, should I give them all static ip addresses?
You can safely ignore them unless you're having problems. Giving the device a static ip will get rid of the request though I believe, if you want to try.
That's mostly all I see in my logs day to day. They're more of an irritant than a problem. It would be nice to have an 'quiet-dhcp' option like tomato. Maybe Merlin can work something out in a future firmware.
log-dhcp=none
Teddy_bear patched dnsmasq to add the option. I managed to track down his commit, shouldn't be a problem to implement.
+ /* option to reduce excessive logging for DHCP packets */
+ if (option_bool(OPT_QUIET_DHCP) && strncmp(type, "DHCP", 4) == 0)
+ return;
Code:+ /* option to reduce excessive logging for DHCP packets */ + if (option_bool(OPT_QUIET_DHCP) && strncmp(type, "DHCP", 4) == 0) + return;
See - no worries - even without the patch above...
Welcome To SNBForums
