Ipad killing my network. help please
starfox101
I'm having some wireless problems, First my network is as follows: #1 switch netgear gs108T #2 switch netgear gs108T, Router is netgear FVS336G. All wired cat 5e. I have a Synology 508 NAS I stream movies to a Netgear 9150. The #1 and #2 switch are connected Link Aggregation. The 508 is connected Link Aggregation to the #1 switch. #2 switch is connected to the router. Now for the problem, I connected a Belkin N1 wireless router setup in AP mode. To the FVS336g. Wife has a new Ipad. When the Ipad is around and connected wireless it kills my movies, just lock's up the movie. Modem is connected to the FVS336G dsl.
Thanks for any help
Any reason you can't use the Belkin as a router and put the iPad on another subnet? I am guessing that maybe bonjour is the culprit, not sure if you can disable it on the NAS, so separation of networks could fix it. Try a network packet analysis.
I'm having some wireless problems, The #1 and #2 switch are connected Link Aggregation.
Thanks for any help
Try not using Link Aggregation... seems to me that on a gigE LAN with mere PCs and the NAS, single gigE speeds are more than adequate and won't be reached with this gear.
Also... the Belkin router has a formal AP mode? With DHCP disabled?
Thanks much for the help, problem is the same with or without link aggregation. The belkin is in AP mode. Not sure about DHCP. I have the FVS336g set for no more the XXX.025. The belkin starts a XXX.035.
I will check on the bonjour that may be the problem..
Thanks again
you shouldn't have multiple dhcp on the same subnet.
Thanks again
if there are two DHCP servers enabled, the iPAD could get a duplicate LAN address that conflicts with that issued by the DHCP server in your real router.
We'll your first problem is having a Belkin for a for a router. :)
Second you only need 1 DHCP server per subnet. More than 1 can cause ip conflicts or no ip address at all.
I'd make sure only one router on the same subnet has DHCP enabled.
