Iptable command to cause packet loss
Can you explain your scenario a bit more.
Also, what do you mean by "per IP address", an IP address on your LAN? Unsolicited traffic from the internet will be dropped by iptables FORWARD chain. That's 100% packet loss for the sender.
What I want to do is to randomly drop a percentage of all incoming packets to one of my lan devices, to basically simulate a poor internet connection!
I don't think it's possible to do it with iptables on the router because it doesn't have the required modules (statistic or random).
HOWTO
Enable the statistic match module in the firmware build configuration
vi ~/asuswrt-merlin/release/src-rt-6.x.4708/linux/linux-2.6.36/config_base.6a
OLD LINE: # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
NEW LINE: CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
Build the firmware
make clean
make {target-platform}
Copy the new kernel module to your router /jffs/bin folder. My routers is RT-AC68U and RT-AC56U, both ARM architectures. Use 'find' command to search for the kernel module, xt_statistic.ko.
find ~/asuswrt-merlin -type f -name "xt_statistic.ko"
### here it is:  ~/asuswrt-merlin/release/src/router/arm-uclibc/target/lib/modules/2.6.36.4brcmarm/kernel/net/netfilter/xt_statistic.ko
Now login to the router to install and load the module
insmod /jffs/bin/xt_statistic.ko
modprobe xt_statistic
Now this works
iptables -A INPUT -m statistic --mode random --probability 0.1 -j DROP
iptables -A OUTPUT -m statistic --mode random --probability 0.1 -j DROP
Undo it when you're done playing around
iptables -D INPUT -m statistic --mode random --probability 0.1 -j DROP
iptables -D OUTPUT -m statistic --mode random --probability 0.1 -j DROP
Download: http://www.megafileupload.com/21Eh/xt_statistic_asuswrt-merlin-378.53-arm.rar
MD5: 1bbd3bfc76be38b3a1903d11ffb420bb
