iptables issue or no?
  • Thread starter Thread starter Deleted member 27741
  • Start date Start date
D
Guest
Hi, I have a certain iptables rule that is driving me nuts.
When I add port forwards, everything is fine with all of them but one. It is a port forward like-
forwardname 6000 local.ip.address 6000
For whatever reason this and ONLY this port forward shows up in the NAT iptable with a dpt of X?
tcp dpt:X to:local.ip.address:6000
All others show a correct dpt. I have reset the router. I have deleted the rule and rebooted (and added rule again). Reset the rule multiple times (delete and re-add). Added the rule with a different name. Done a rain dance and used the force. Still can't get that freakin' rule in iptables to say the right dpt. :mad::mad: The problem only occurs with the port forward to port 6000. Problem or no? :confused::confused:
p.s. I call the nat iptable with this command:
iptables -t nat -L -v --line-numbers -x
Great, thanks! What the %$@ is X server? :):) I suppose I should move that service away from port 6000.
