IPTables Noob
Johnathon
I am trying to write or append additional rules into the IPtables within the router as there are some random ports open on the device that I would like to close. I read over the wiki and did some googling but I am really not clear as to how I can setup the router to drop udp/tcp traffic from any source to those ports.
If anyone could offer any guidance I would appreciate it. I edited the file manually and it didn't retain upon reboot, the wiki doesn't really address it and I am unsure how the iptables command works via the ssh shell.
Also, there is talk of lots of scripts, is there a repository someone could link me to?
Thanks for your patience.
J
It would be better if you just "turned off" any ports that are open rather than spending a lot of time creating custom scripts with firewall rules.
What are the ports that are open?
I would close everything, and whitelist the ports needed, like this:
There is not a single port open to the Wan by default, so I'm not sure what you are trying to accomplish here.
Sent from my P027 using Tapatalk
I suspect he might be talking about ports that are open on the LAN side. However, unless @Johnathon gives us more detailed information we can't help him.
