iptables script by NAT-START not effective after WAN changed?
Lecan
When WAN changed like WAN was restored ,my iptables-set script trigger by nat-start, but not effective, It appears that some WAN events were triggered and clear the iptables after my script run.
May 14 18:49:15 pppd[25845]: Plugin rp-pppoe.so loaded.
May 14 18:49:15 pppd[25845]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.7
May 14 18:49:15 pppd[25857]: pppd 2.4.7 started by lijeep, uid 0
May 14 18:49:15 pppd[25857]: PPP session is 17237 (0x4355)
May 14 18:49:15 pppd[25857]: Connected to cc:1a:fa:ed:14:00 via interface eth1
May 14 18:49:15 kernel: Assigning idx[40] for ppp0
May 14 18:49:15 pppd[25857]: Using interface ppp0
May 14 18:49:15 pppd[25857]: Connect: ppp0 <--> eth1
May 14 18:49:15 pppd[25857]: Remote message: Authentication Successful,Welcome!
May 14 18:49:15 pppd[25857]: PAP authentication succeeded
May 14 18:49:15 pppd[25857]: peer from calling number CC:1A:FA:ED:14:00 authorized
May 14 18:49:15 lldpd[3764]: removal request for address of ***%40, but no knowledge of it
May 14 18:49:15 pppd[25857]: local  IP address ***
May 14 18:49:15 pppd[25857]: remote IP address ***
May 14 18:49:15 pppd[25857]: primary   DNS address ***
May 14 18:49:15 pppd[25857]: secondary DNS address ***
May 14 18:49:15 custom_script: Running /jffs/scripts/nat-start
May 14 18:49:15 me: xray proxy is running after 0s
May 14 18:49:15 me: set ip-list success
May 14 18:49:15 me: ip rule already exist
May 14 18:49:15 me: set ip route success
May 14 18:49:15 me: set iptables success
May 14 18:49:16 dnsmasq[25428]: read /etc/hosts - 22 names
May 14 18:49:16 dnsmasq[25428]: using nameserver ***#53
May 14 18:49:16 wan: finish adding multi routes
May 14 18:49:16 openvpn-routing: Applying all killswitches
May 14 18:49:16 miniupnpd[25421]: shutting down MiniUPnPd
May 14 18:49:21 miniupnpd[26225]: HTTP listening on port 33063
May 14 18:49:21 miniupnpd[26225]: no HTTP IPv6 address, disabling IPv6
May 14 18:49:21 miniupnpd[26225]: Listening for NAT-PMP/PCP traffic on port 5351
May 14 18:49:21 rc_service: ip-up 25866:notify_rc stop_samba
May 14 18:49:21 wsdd2[25448]: terminating.
May 14 18:49:21 Samba_Server: smb daemon is stopped
May 14 18:49:22 rc_service: ip-up 25866:notify_rc start_samba
May 14 18:49:22 dnsmasq[25428]: exiting on receipt of SIGTERM
May 14 18:49:22 custom_config: Appending content of /jffs/configs/dnsmasq.conf.add.
May 14 18:49:22 dnsmasq[26238]: started, version 2.90 cachesize 1500
May 14 18:49:22 dnsmasq[26238]: asynchronous logging enabled, queue limit is 5 messages
May 14 18:49:22 dnsmasq-dhcp[26238]: DHCP, IP range 192.168.50.2 -- 192.168.50.254, lease time 1d
May 14 18:49:22 dnsmasq[26238]: read /etc/hosts - 22 names
May 14 18:49:22 dnsmasq[26238]: using nameserver ***#53
May 14 18:49:22 Samba_Server: daemon is started
May 14 18:49:22 wsdd2[26258]: starting.
May 14 18:49:23 wan_up: Restart DDNS
Keep in mind that nat-start mostly targets the NAT/mangle tables, while firewall-start will target the filter table.
yes, my script is set the mangle table only, and it works fine with router start or reboot, only broken when WAN changed.
