IPTV problems with openvpn
eighteen
Hello!
I am from Portugal and I use an IPTV service from an operator.
My router is a Netgear R7000 with the Firmware Asus-Xwrt 380.65, and the problem I have happens when I connect the openvpn client through IPVANISH, some IPTV services stop working, I can not access them, shutting openvpn back to work .
The strange thing is that I have several fixed ips of my network added in the option police rules and none of these ips is the one of the box that supports the service IPTV.
What is causing these problems when I activate vpn?
Not sure if you IPTV is fiber or what service it is. maybe you can tell us.
I am not sure if Netgear has a IPTV section as in the ASUS routers
but if it does you need to put it in manual settings and find out the VLAN that your IPTV uses and enter it in one of the VLAN settings. this way your IPTV will get routed via the router and then to your receiver.
