D
Deleted member 22229
Guest
Just want to verify i have this set up properly. Do i understand correctly you must enter your IPv6 link local address found under system IPv6 tab and enter that as a DNS server under the IPv6 tab ? I picked 2 ipv4 and 2 ipv6 adresses from the drop down menu on the wan page and enabled DNS/TLS.
Also should i enable DNS filtering. And how should this be set up. Thanks !! ( Enabled this set it to router and entered the clients in the list. )
Apparently it does not work this site https://tenta.com/test Says TLS is not enabled although in the router it is. Does this feature actually work every time i try it it seems to fail.
