IPv6 on Lan Ports only or ipv6 exclude on Wifi
Pommes
Hello,
i have an RT-AC87U.
On Lan port i have an Xbox which works better when connected via ipv4 and ipv6.
Wifi connected i have an Apple TV, which connects to policy rule vpns.
When i enable ipv6 on the router the vpn of apple tv do not work properly because of leakage.
so i see 3 solutions:
1. Is it possible to enable ipv6 on lan only, not on wifi?
2. Is it possible to enable ipv6 on only one device( Xbox Mac address)?
3. Is it possible to block all ipv6 in-and out-bound traffic for all clients but one?
On xbox and apple tv there are no settings for ipv6.
Does anyone here have another solution to achieve my goals?
Thank you very much
Pommes
Hello,
i have an RT-AC87U.
Thank you very much
I solved the problem by deeper searching this forum, thanks a lot,
heres the solution:
