Is 73°C normal for Asus RT-AC68U CPU?
xiaokai
Hi
Quick small question, are these temperatures normal for an Asus RT-AC68U
2.4 GHz: 49°C
5 GHz: 50°C
CPU: 73°C
Its running 24/7 for 17 days so far. With around 11 to 15 clients connected.
Connected to a VPN server.
Ambient temperature is around 22°C
Xiao
Hi
2.4 GHz: 49°C
5 GHz: 50°C
CPU: 73°C
Xiao
Yes normal
My 68 u with 6 devices hooked
2.4ghz= 47 C (idle)
5 GHZ=disable
Cpu=72(idle)
Hi
2.4 GHz: 49°C
5 GHz: 50°C
CPU: 73°C
Xiao
Normal.. Your lucky others have there routers much hotter. :eek:
You are so lucky. My AC68U is so hot that I had to cool it in front of an electric fan:
已开机时间
6 天 20 时 2 分 46 秒
Temperatures 2.4 GHz: 49°C - 5 GHz: disabled - CPU: 78°C
CPU
CPU Model
ARMv7 Processor rev 0 (v7l) - (Cores: 2)
CPU Frequency 800 MHz
CPU Load Average (1, 5, 15 mins) 0.16, 0.05, 0.06
Memory
Total
249.75 MB
Free 191.22 MB
Buffers 2.44 MB
Swap usage 0.01 / 512.00 MB
Internal Storage
My AC68U is always somewhere between 80-90° degrees - as no problem with this temps, so and not cooling needed! :rolleyes:
I run Transmission on the router with 1 core always at 100% load and the 2nd on below 50% - again: No problem with this temp as the CPU is build to survive even higher temps - I recall that everything below 125° is OK. ;)
With kind regards
Joe :cool:
normal values! i had to use a fan to lower temperatures. manage to get them down from 86 to 71 with a 9v fan.
With kind regards
Joe :cool:
Though it may be true that the CPU itself can handle those high temps the componets around the CPU can not and can fail. Asus has done a very poor job on the heat sinks and venting of the router they should not get that hot and need active cooling. The Neatgear R-7000 uses the same or very similar duel core chip and the router runs much cooler only around 60c with no active cooling.
I must agree with you about these high temps. While it seems like it work fine within this temperature i sincirely dont feel safe having such high temperatures for many time.
Really? I should have heard it earlier. Or else I won't add two little fans to my AC56U. R7000 PCB board: 6182_11_netgear_nighthawk_r7000_ac1900_smart_wi_fi_router_review_full.jpg
It's indicative to a solution for better AC56U/AC68U heat dissipation. Replace the tiny thermal pad in Asus with bigger ones if not a single giant pad:cool:
