I would not expect a difference using only one MU-MIMO device. Only when using two or more simultaneously.My Galaxy S7 supports MU-MIMO and maybe a few more cell phones. I can't really say I see huge improvements while using my cell to watch Netflix or Youtube videos.
That means it's a BRCM MU-MIMO chipset.some of the smartphones, we've had reports on the forums where they go from 2-stream operation down to single stream if MU == true
What router are you using?Is all MU-MIMO Router systen 4x4 11ac 80MHz BUT only 2x2 160/80+80MHz in MU-MIMO mode?
I have 3 MU-MIMO clients two laptops and 1 phone but when i use MU-MIMO mode the NONE MU-MIMO clients gets slower speed and star to lag, its that normal?
So the MU-MIMO is off in my router
Devices that do not support MU-MIMO (SU) should be, best case, unaffected. The theory is that MU-MIMO devices should free up airtime for SU devices. So, if anything, SU devices should get more bandwidth.
But real life for MU can be very different.
I have tested MU-MIMO devices at close range. Side by side or separated by 180 degrees makes little difference.
In thinking more about this topic, I wonder, is it possible for router makers to detect which clients support MU-MIMO and provide that data in the devices list?
Ok here goes. I tested using a Pixel XL and a Pixel 2 XL with my 86U on 384.3. Phones were sitting 1 inch apart on the coffee table about 12 feet and one wall away from the router. Each had a 866 link speed. I ran the test using the web based DSLReports speed test. I ran 5 tests and took the average of the best 4 values. Results are DL/UL in Mbps.
Testing phones one at a time to set a baseline.
Pixel XL 582/479
Pixel 2 XL 536/571
Testing phones at the same time with MU-MIMO disabled
Pixel XL 410/329
Pixel 2 XL 274/410
After this test I "forgot" the wifi connection on each phone. I enabled MU-MIMO and rebooted the router.
Testing phones at the same time with MU-MIMO enabled
Pixel XL 264/145
Pixel 2 XL 272/468
The values for both tests when testing both phones at the same time were all over the place. Looking at the results it appears that total throughput is higher with MU-MIMO disabled in my environment and configuration.
I do have a non-MU-MIMO 2x2 Moto X Pure Ed that I could add to the mix if there is value in testing all three together. Just let me know.
On the System Log>Wireless Log page both of my phones show an "M" flag and per the legend M=MU Beamforming.
Welcome To SNBForums
