Is Asus TUF AX3000 supported?
Huike
Is the Asus TUF AX3000 supported by Merlin firmware? Or can I just use the RT-AX58U firmware? Thanks.
Probably no to both.
You bought a gaming router that has specialised firmware , IF it were possible to flash either firmwares you mention all your gaming settings would be lost.
You would have got a quick answer had you used Google or the forum search facility.
Now I have had time to search my earlier posts I can tell you the answer is absolutely NO to both of your questions.
Any attempt to flash these firmwares will brick your router.
See these treads / posts:
Error flashing firmware
TUF gaming router / Merlin
