Is Huawei AX3 Pro worth buying?
artup
There's new cheap wifi6 router available. I want to buy 3 units to create mesh network for 18 clients. I need a vpn access to the network and this is not possible with this router but I could use raspbery pi to create vpn access
Artur
L&LD
Part of the Furniture
K-2SO
Don't mix politics with technology. Huawei is the world's largest telecom equipment manufacturer and second largest cellphone manufacturer. Allegations, accusations, bans... $122 billion revenue in 2019. The dogs bark, but the caravan goes on. In regards of AX3 Pro router, reviews in multiple places show good performance. I use Huawei HG532e ADSL modem/router in a remote location. In last 7 years it never failed once. In comparison my last 2 Asus routers both failed in 2 years time.
Poseidon
Say NO to Huawei and anything Chinese owned/manufactured! There’s a reason they are BANNED in the US and now in the UK among several other countries too.
They steal technology from other nations and they are also reasonable claims they spy on the consumer as well. Stay away!
K-2SO
Let’s ban Google too. They spy on the consumers more than anyone else. Oh, it’s a US company. It’s allowed. :rolleyes:
Prasanna Ariyanayagam
I have bought two and use mesh. Very very fast. The setup is in Chinese though but you can auto translate in Google but only after you set the basics up (in Chinese) to get internet as you need internet to translate. Speeds are 100MBps in the same room and one floor below I get 77MBps. I might get a third one.
artup
I have read that it supports OFDMA but could't confirm that on Huawei 's web page. Can you check it on product sheet that came with the unit?
Artur
Krisbi
Does the AX3 Pro support WPA2 Enterprise or even WPA3 Enterprise? Have you found anything saying RADIUS based dynamic VLAN assignment? What about airtime fairness, 802.11k, 802.11r,...? What about maximum concurrent SSIDs?
