Check your system log to determine which step of the boot gets stalled for such a long time. Complete boot time shouldn't be that long.
Thanks for replying. I checked the log. Nothing seems unusual. The problem is even though I can see the LEDs for the 2.4GHz and 5GHz bands enabled almost a minute after turning the router on, it takes much longer for me to detect the signal. In fact I start detecting the 5GHz signal about 2 minutes after detecting the 2GHz signal. Is that normal ?
This is the log. Note that I turned on the router at 16:52:30, but the first entry is registered at 16:53:51.
Jun 19 16:53:51 rc_service: ntp 740:notify_rc restart_upnp
Jun 19 16:53:51 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jun 19 16:53:52 kernel: SCSI subsystem initialized
Jun 19 16:53:53 kernel: csw_retry 100
Jun 19 16:53:54 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Jun 19 16:53:54 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Jun 19 16:53:54 kernel: usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
Jun 19 16:53:56 kernel: xhci_hcd 0000:00:0c.0: WARN: short transfer on control ep
Jun 19 16:53:56 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 1
Jun 19 16:53:56 kernel: xhci_hcd 0000:00:0c.0: WARN no SS endpoint bMaxBurst
Jun 19 16:53:56 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 2
Jun 19 16:53:56 rc_service: ntp 740:notify_rc restart_diskmon
Jun 19 16:53:56 disk_monitor: Finish
Jun 19 16:53:56 kernel: scsi 0:0:0:0: Direct-Access USB 2.0 Flash Disk 0.00 PQ: 0 ANSI: 2
Jun 19 16:53:56 kernel: sd 0:0:0:0: [sda] 4030463 512-byte logical blocks: (2.06 GB/1.92 GiB)
Jun 19 16:53:56 kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 19 16:53:56 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jun 19 16:53:56 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 19 16:53:57 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jun 19 16:53:57 kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Jun 19 16:53:57 kernel: scsi 1:0:0:0: Direct-Access TOSHIBA MQ02ABD100H 8102 PQ: 0 ANSI: 6
Jun 19 16:53:57 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jun 19 16:53:57 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jun 19 16:53:59 kernel: sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
Jun 19 16:53:59 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jun 19 16:53:59 kernel: sd 1:0:0:0: [sdb] Write Protect is off
Jun 19 16:53:59 kernel: sd 1:0:0:0: [sdb] Assuming drive cache: write through
Jun 19 16:53:59 kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Jun 19 16:53:59 disk monitor: be idle
Jun 19 16:53:59 kernel: tfat warning (device sda1, pid 1426): fat_fill_super(): FAT volume ROUTER is dirty. You should unmount and repair it.
Jun 19 16:53:59 usb: USB vfat fs at /dev/sda1 mounted on /tmp/mnt/ROUTER.
Jun 19 16:53:59 rc_service: hotplug 1417:notify_rc restart_nasapps
Jun 19 16:54:00 iTunes: daemon is stopped
Jun 19 16:54:00 FTP Server: daemon is stopped
Jun 19 16:54:02 Samba Server: smb daemon is stopped
Jun 19 16:54:02 kernel: gro disabled
Jun 19 16:54:02 Timemachine: daemon is stopped
Jun 19 16:54:02 kernel: gro enabled with interval 2
Jun 19 16:54:05 Samba Server: daemon is started
Jun 19 16:54:07 usb: USB /dev/sdb5(ntfs) failed to mount At the first try!
Jun 19 16:54:07 usb: USB ntfs fs at /dev/sdb5 mounted on /tmp/mnt/Movies.
Jun 19 16:54:07 asusware: umount partition /dev/sdb5...
Jun 19 16:54:07 disk monitor: unmount partition
Jun 19 16:54:08 syslog: USB partition unmounted from /tmp/mnt/Movies
Jun 19 16:54:08 asusware: Automatically scan partition /dev/sdb5...
Jun 19 16:54:08 disk monitor: scan partition
Jun 19 16:54:12 asusware: re-mount partition /dev/sdb5...
Jun 19 16:54:12 disk monitor: re-mount partition
Jun 19 16:54:12 usb: USB /dev/sdb5(ntfs) failed to mount At the first try!
Jun 19 16:54:12 usb: USB ntfs fs at /dev/sdb5 mounted on /tmp/mnt/Movies.
Jun 19 16:54:12 asusware: done.
Jun 19 16:54:12 disk monitor: done
Jun 19 16:54:13 admin: sh /opt/S50asuslighttpd.1 start
Jun 19 16:54:19 admin: sh /opt/S50downloadmaster.1 start
Jun 19 16:54:20 crond[483]: time disparity of 991733 minutes detected
Jun 19 16:54:24 transmission-daemon[2771]: Couldn't bind port 51413 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:380)
Jun 19 16:54:24 transmission-daemon[2771]: UDP Failed to set receive buffer: requested 4194304, got 245760 (tr-udp.c:84)
Jun 19 16:54:24 transmission-daemon[2771]: UDP Failed to set send buffer: requested 1048576, got 245760 (tr-udp.c:95)
Jun 19 16:54:33 rc_service: hotplug 1447:notify_rc restart_nasapps
Jun 19 16:54:33 iTunes: daemon is stopped
Jun 19 16:54:33 FTP Server: daemon is stopped
Jun 19 16:54:35 Samba Server: smb daemon is stopped
Jun 19 16:54:35 kernel: gro disabled
Jun 19 16:54:35 Timemachine: daemon is stopped
Jun 19 16:54:35 kernel: gro enabled with interval 2
Jun 19 16:54:36 Samba Server: daemon is started
