Is my lan slowing down?
ugo1
Hi
here a test of a month ago:
Microsoft Windows XP [Versione 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Ugo Merlini>G:
G:\>iperf -w 64k -c 192.168.0.6 -r
Server listening on TCP port 5001
TCP window size: 64.0 KByte
Client connecting to 192.168.0.6, TCP port 5001
[1844] local 192.168.0.10 port 1041 connected with 192.168.0.6 port 5001
[ ID] Interval Transfer Bandwidth
[1844] 0.0-10.0 sec 1.00 GBytes 860 Mbits/sec
[1944] local 192.168.0.10 port 5001 connected with 192.168.0.6 port 33544
[1944] 0.0-10.0 sec 752 MBytes 631 Mbits/sec
and here the one I made today:
[1844] local 192.168.0.10 port 1158 connected with 192.168.0.6 port 5001
[1844] 0.0-10.0 sec 934 MBytes 783 Mbits/sec
[1944] local 192.168.0.10 port 5001 connected with 192.168.0.6 port 52613
[1944] 0.0-10.0 sec 803 MBytes 674 Mbits/sec
Is my lan slowing down or is a false problem?
Regards
Ugo
When you make tests like these, you must average over a period longer than 10 seconds and ensure that there is no other traffic on the LAN while you are making the measurement.
I suggest at least a minute for the measurement period.
And to answer your question, there is probably no problem.
