Is overhead fan (Ceiling Fan) an enemy of Wi-Fi?
Do you think overhead fan cause Wi-fi to slow down?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
    0
Sachb
I've noticed that whenever I switch on the fan, my wifi speeds tend to drop by 50-100 mbps & more, so I wanted to discuss this and find out if there was a solution.
As per the article below, it seems that Wi-Fi signals do get caught up by the Blades moving at faster rate due to the EMI, I believe.
Link: https://empirenews.net/ceiling-fans-can-cause-wi-fi-particles-to-break-down-slow-down-home-internet/
This thing seems to have been unnoticed, and nobody talks about it.
What are your thoughts on it? Have you faced a similar issues those having overhead fans?
First, do some research about the validity of things you cite.
https://realorsatire.com/empirenews-net/
What happens, according to researchers, is the movement of a ceiling fan sucks in the Wi-Fi particles that are floating through the air, making your ‘network’ stuck in a type of internet tornado.
Seriously?
That said, it's possible that if the fan has a speed controller, it could be generating RF interference.
