Is site-to-site VPN possible with RT-AC68R
SedonaRider
I purchased a RT-AC68R to replace my old wireless router. The old wireless router has a VPN tunnel established to another house. Is it possible to set the RT-AC68R up with the same configuration? I am not an expert at this, but I do not see a similar VPN configuration for site-to-site.
probably. depends on the vpn server. without having to install extra crap, you shouldn't have a problem setting up the ac68r as a pptp client. openvpn of course would be better. i think you can do ipsec if you dig around and get it installed. probably want to make sure your lan subnet is different than the server's, etc.
