Is there any way to enable secondary Ip?
That's a really horrible solution! A better answer is to do what is suggested in the comments; to create a hosts file entry for www.skype.com that points to 127.0.0.1
It is unclear from the post whether the camera is a network device that connects straight to the router, or whether it connects to a PC and it is the PC that connects to the internet.
If the camera is connected through the PC you just need to edit C:\Windows\System32\drivers\etc\hosts
If the camera is connected to the router, create a /jffs/configs/hosts.add file that contains this line:
127.0.0.1 www.skype.com
See https://github.com/RMerl/asuswrt-merlin/wiki/Custom-config-files
Gah, not used Jffs for a while, completely forgot how to use it!
I've got Jffs enabled and logged into the router via putty, completely forgot what to do from here! Any help anyone!?
cd /jffs/configs
echo "127.0.0.1 www.skype.com" > hosts.add
chmod 777 hosts.add
Reboot the router and then the camera.
Thanks Colin, worked a treat. A owe you a pint, the mrs was going crazy about not being able to Skype her mother!
